TDC Sensor
MLB
Struggling to start first time recently and totally failed without being able to restart last week so by the sound of it the TDC sensor has gone.
Lots of options available, are they all the same as long as they come with the new loom bit?
Like this one?
ex-Chinese Dave
I had the same issue and recently had a new one fitted. Before that I removed the original one, used wet and dry sandpaper on the sensor part and refitted it (I just removed the 2 10mm nuts to get at it). It worked ok after that.
  • Like
Reactions: MLB
MLB
For the amount of work to get there and price of above linked part I think I'd rather put a new one in, but glad it sounds like this is the issue and it sorted it for you!
TheBandit
  Monaco172, Green1.2
Mine would also only start on second key turn. Genuine new loom section + tdc sensor sorted it, now starts first time every time. No idea on cost/place to buy from as it came with the car! Hopefully it sorts your issues
TDC Sensor: 8200647554
Loom: 8200673202
Shade under £100 for both from RPD (not including delivery)
  • Like
Reactions: MLB
ex-Chinese Dave
I was told that the fuel pump doesn't pressurise on the first key turn. If I turn the ignition on, without firing, then off and then go to start it fires perfectly every time.
TheBandit
  Monaco172, Green1.2
I read that too, I bought a second hand pump in case the new TDC didn't sort it. I have also read the horror stories of refitting the pump housing ring so glad the sensor fixed it for me 😅
