Temperamental starting
  Renault Clio '02 1.4
Hi.
I have a Renault Clio 2002 1.4 Dynamique, I've had it since Easter
but the cambelt went a month later so it's been completely over hauled inside & had a 2nd hand cylinder put in.
Ever since then I have had problems with it starting, not every time but still enough to annoy the hell out of me as its cost me a few bob. It was also written off 4 years prior to me owning it as it was then sold to the owner I got it from. I put the key in as normal and the immobiliser light goes out & it turns over but there's no spark. I try to pump the gas a bit as well but not sure that helps. Sometimes I've had to just leave it where it is cause it just won't start other times it starts 3/4 time.
Can anyone help? At the end of my tether.
I managed to get a mechanic friend to put it on lap top and it didn't state TDC sensor but could it still be a problem?
it did however say that the starter motor relay had a fault code.
