Testing Injector plugs
RichValver
  Clio 16v/172 daily
Can anyone help me out and tell me how to test injector plugs?
I have a multimeter but cant seem to get a reading from them.
I Have error code P0300/multiple missfire but it only seems to be at certain revs
Changed 3 different injectors now and changed coilpack so suspecting the wiring or atleast want to rule it out
thanks in advance
  dan's cast offs.
Perm 12v with ignition and pulsed earth on cranking.
Decent code reader will tell you what cylinder is the issue.
RichValver
  Clio 16v/172 daily
Yeah I know how to test the actual inject but I was looking to test the actual wiring. It seems its an injector at fault anyway
Thanks for the input though :)
Because they're pulse-width modulated you'll struggle to pick them up on a cheapy multimeter. Best you could do would be to continuity trace the plug back to the ECU.
