Clio 172 ph2 red
hi guys,
mij clio has an problem (not the driver this time). I've a clio 172 ph2. I lowered it with coilovers. At first i lowered it at the lowest possible point..... a bit of shaving here and there not what i wasn't used to with my first clio.
After i let it align i noticed something when i took a left turn it felt like my right front wheel was wobbling over the road. Like it realy didn't wat to go there. Brought it to a renault mechanic friend of mine and he said the axle(? my mechanical english isn't the best) stood in a strong angle... so he thougt it was the trouble maker...
replaced it with a brand new one.. looked liked the problem was gone... let it align again... and gues what..
next possibility the wheel bearing... took it apart so he could press a new one in it.. mounted everything and and took a testdrive... the probleem seemed worser and almost not drivable.... managed to get to my friend and we looked... there was rubber on the rings to adjust the coilover so we thought is was to low and camber was the problem.... I put it 2-3 cm higher and made a new appointment for alignment
after the ride home from a new alignment i already noticed... so back to my friend ... the rubber from the axle was torn and all the oil was spread around it.. Replaced it with the old one cause we thought it had been the rubbing against the wheel at first..
and after the latest allignment it is still not gone
The problems i now have:
wobbling effect when I take a roundabout (here you have to steer left )
When I accelerate i am going to the right side
braking keeps it steady for so far i tested
when I let it role out it goes right slowly
also tried my winterwheels same proble
Hope someone can help me because the clio tuning (and problemsolving i hope) scene is bigger here.
p.s. are there special products for lowered cars like special supporting brackets or something ? or will the 182 type be better for it something ? als because the front wheels aren't centered anymore and mybe i could solve that
greeting stefan
My spellingscheck gave everything a red stripe so i hope its readable.
greeting stefan
