Tilt Lense Photography
The Boosh!
ClioSport Admin
  Elise, Duster
ANyone had a go at this?
Would you say its a bit gimmicky or do you use the lense regularly?
Really like the effect it produces.
  Chav Rocket
never heard of it till just now, but looking at those photos and some others on google i think its pretty neat
  172 Cup
Tilt shift? There's a massive thread on here somewhere about it iirc..
One of my really early efforts -
  Oil Burner
When done well it looks superb. However to do it properly you need the lenses (£600+), you can replicate the results using photoshop, but it doesnt look quite the same (although some are done superbly).
I would love a tiltshift lens, but its a bit of a 1 trick pony and you would probably only use it once an event at most.
We've got a tilt shift lens at work, I've only had a quick play with it, quite hard to use to begin with. It's useful for product photography as you can increase the depth of field etc.
I like the effect,
The tilt shift lenses are as said expensive and i couldn't justify it over say a macro or wide angle lense that would be used in every day use...
  Oil Burner
The lens doesnt just reduce DOF front/back, depending what tilt you use you can increase the DOF, move the DOF, do all sorts of weird stuff. Apparently useful for portraits too. I might hire one sometime looks like a laugh.
  Titanium 182
Just take a normal picture, blur the corners. There's a little more to it than that, but I wouldn't go spending out on a new lens for the effect!
