Turini's on a Mk1?
if the offset of the wheels is 37/38 and has the same pcd then should be fine, may rub a bit dependant on tyres, is the ph3 lowered at all mate?if you get 195(may need to be wider tho)/40 rubber should imaging they will fit....
No its not lowered, but it will be...
Ive seen a site with a chart on and it says i can fit 195/40/16, 4x100, 35-45 Offset and a 60.1 Bore
That means nothing to me :o
Do they come in that size?
