Quote: Originally posted by MarkCup on 21 July 2004
Underinflated?
would be the same on the inner edge not just the outer
tell me about itQuote: Originally posted by Toypop on 21 July 2004
Corning hard wears the outside of the tyres. This outside of the front left will tend to wear more as this is your "roundabout" tyre.
Quote: Originally posted by 172loony on 21 July 2004
tbh if the tracking has been done then it must just be due to cornering as its the outside edge that takes the brunt of the wear. also its nothing to do with lowering as youll end up with more negative camber so will be more likely to wear the inner edge. dont worry about it too much as long as the centre 3/4 of the tyre are over the limit youll be fine, cops cant do anything but its normally better if you still have visible tread on the outer edges. tbh i dont tend to run tyres til they are at the wear bars as youll notice a loss of grip. normally more noticeable when pulling away from stationary in the wet when the tyres are getting low
