Are there any guides on uch removal? Any previous threads?
GrahamS ClioSport Club Member 335d May 17, 2014 #2 13mm bolt behind the bonnet release trim. Torx screw next to the fuse box. The edge is clipped over the dash frame. Should then wiggle out
C chepch 172 Ph1 May 18, 2014 #3 How do I remove the wires? Have relays pulled and it doesn't seem obvious how to release wires. Also so my uch is white. Is it different to 'normal'?? Thanks.
