A4 Quattro, 172+182
Hi all
My clio 182 drivers window has decided to play up and it's had a new switch and window regulator and the problem is still there. The UCH has been stripped and I found a fuse blown and hey presto the window worked but the 1 touch wasn't working so I made do but now the window has packed up again. Is it possible to change the UCH for a second hand 1 without any issues or will I need to replace the keys and ECU etc?
