found this article on the web, any truth behind it?
"The problems that this lack of stiffer torsion bars create is that like a lot of front wheel drive cars and especially French cars, the rear suspension is set too high and too soft as standard. When you lower and stiffen the front this unbalanced situation is made worse. Sadly, many suppliers of these kits and supported by articles in motor magazines say the answer is to lower the rear suspension to make the car level again by just turning the torsion bars around on their splines. This is definitely not a solution but merely way of getting around a problem that hopefully not too many people understand the reason why it is not a proper fix. The reason it is not a fix is that to make the cars sit lower you have to take tension off the bar, which exactly the opposite of what is necessary. Yes, it will lower the suspension to get it looking good and level with the front but thats all. If you put on some lowered uprated front springs you will make the handling worse unless you can fit uprated rear torsion bars. If you are more concerned with appearance then this modification is OK but if improved handling is required it is definitely not. "
Never heard of uprated torsion bars personally, anyone?
pete
