Visual Basic Help Please...
  Saxo VTS
Yes it's assingment time again and as usual FincH wasn't listening properly in class!
I've got a nasty file handling exercise to do and am a bit stuck on formating me trusty old text files!
Code:
Open App.Path & "\Customerlist.txt" For Append As #1
    Dim a As String
    a = txtNewname.Text + vbNewLine
    Write #1, a
Close #1
That's the code I'm using to create, write and add to a file of customers names. All well and good but when I output the file using the following code:
Code:
Open App.Path & "\Customerlist.txt" For Input As #1
While Not EOF(1)
Line Input #1, temp$
alltext$ = alltext$ & temp$ & vbNewLine
Wend
lstCustomers.AddItem alltext$
Close #1
The data output to the list box looks like this:
"Dave Hedgehog""Spud Gun""Richard Richard"
Where as I need it to be each name on a new line and without the quote marks.
Please someone help me! I'll give you my pet Ant called Larry!
Cheers.
  Rav4
You are forced to do VB when at uni/college normally, cannot do any other languages as C# and if you do, they are optional units which are limited or your dissertation.
Rubbish :(
try vbCrLf instead of new line ;)
and use something propper like C# next time!
TeZ
  Non RS : (
Dim a As String your c**k round your neck loser
a = txtNewname.Text +Tez=this thread bores me vbNewLine please
Write. about.some -othershite #1, a
Close down your computer ....NOW #1
  Saxo VTS
Cheers guys. Yeah we've had to use PASCAL, C and now VB.
Write. about.some -others**te #1, a
What's your problem c**k muncher? :D
sn00p
  A blue one.
I've been doing some stuff in C# at work recently and while it and .net are actually pretty good technology I still feel like I'm using a "toy" language because of its speed. I'm amazed at how slow winforms and graphics stuff actually is in it.
Nice language (well it's C on steroids). Nice frameworks. If they just sorted out the performance issues I'd be convinced. (well partially, cross platform becomes a problem - and no, mono doesn't count!).
