water injection
  Clio 182 Trophy 047/500
I have had a little bit of experience with the Aquamist set up, I used to run one on a Calibra turbo running 390bhp, TBH it didnt make a huge difference, reduced intake temp very very slighty.
You would be better off fitting a larger intercool which will reduce the temp more noticable.
If you find that even with the Intercooler the temps are running slighty high, or you are at high revs for long periods of time, then it may be worth adding it to your set up.
  C63 AMG, F430 & 172
ERL Aquamist System 2C Water Injection Kit Ref: erl.806-008
Designed for use with third party engine management system. This water injection kit provides all the necessary hardware to interface with the PWM output signal.
UK RRP ....... £494.42
Turbobits ..... £444.97
Saving you ... £ 49.45
cool im looking at that kit,
steve the car is going to be taking some heavy abuse!!! also i cant get a huge intecooler in as in the front bumber i have to fit
a intercooler, engine oil cooler, supercharger oilcooler and filter and the original water radiator! LOL
boost activated kits are very heath robinson, a mappable water injection system makes a big difference to MBT and resulting torque curve.
