water magnet and mitt
  106 GTi
I only ever rinse my lambswool mitts out with water after use.
As for the drying towel, wack it in the washing machine on 40/50 degree's with some liquid washing detergent, and NO fabric softener.
MRBILLYUK
  FF Jeden Osiem Dwa
I wash my megs lambswool mitt in warm water soapy water ( washing up liquid ) rinse through with cold water then leave to dry naturally .
  RS 200
I just rinse my Lambs wool mitt out with water, using the hose to blast remaining suds off, then fill it up with water and squeeze it until the water inside comes out through the seams taking any dirt or remaining suds with it, giving it a slight rub at the same time to aggitate any thing stuck to it.
Works quite well although the last stage may be for a bit of fun, to see how hard you can squeeze it before the water jumps out of the top where you put your hand in :)
If really soiled which is'nt very often may use a bit of detergent, always left to dry naturally after ringing it out by hand.
Chris
