Headlamps need a 3M correction kit clean
The rear lamp is affected by another lamp that comes on at the same time , poss stop lamp brings on another .
And some corrosion on a brake pipe and both front springs. .
3M kit ordered, new H&R springs coming next week. I take it the bad connection is likely to be at the lamp end. Clean up of contacts and a spray of ACF50
When you brake does the fog light sign flicker on the dash inbetween the rev counter and speedo? As mentioned above just whip the rear lights off and clean up the terminals with a bit of sand paper.
Tested them and nothing lights up incorrectly, took both light clusters out and due to my often anal cleaning you could have eaten your dinner off the insides so I'm at a loss as to what was the problem
