Which solid topmounts?
Nickson
Looking to get a set of solid topmounts, mainly to stop the knocking noises I get from the standard items.
Car is going to be fully polybushed, on a set of Gaz coilovers, and I want a set of topmounts to finish the front suspension setup off..
Anyone any ideas?
Also, links if possible ;)
Cheers!
Ali
  V6, Trackhawk, GTS
Nothing at all wrong with the OEM top mounts. I had the compbrake ones...(bad rep) took them off and sold them on! OEM was far better 'overall' for road and track.
  ITB'd MK1
the k-tec ones defintely make a positive difference. The knocking will be the top cup hitting the inside of the hole it sits in, which the renualt solution to is a bit of grinding with a dremel
