Whiteline ARB
  S3, Polo
Great! Hadn't seen that thread - just happened to be speaking to a friend of mine and he said uprated ARB's transformed how planted his car felt.
Whiteline was one of the first brands I looked at...
In that thread, it mentions an adjustable ARB being ~£105 - on Whiteline's site, it's £150! :eek:
ForceIndia
  Gentlemans spec 200
Standard non-adjustable is ~100. Adjustable is more like £130 plus. I'm looking around for the best deal.
I know these have been proven to work really well on a lot of cars, like the mk4 golf, as these are heavy cars with a lot of body roll, however I think you should be weary as these do tend to make the rear end a little 'lively'.
Just a thought before you go and buy one.
found this.......Anti-roll bars provide two main functions. The first function is the reduction of body lean. The reduction of body lean is dependent on the total roll stiffness of the vehicle. Increasing the total roll stiffness of a vehicle does not change the steady state total load (weight) transfer from the inside wheels to the outside wheels, it only reduces body lean. The total lateral load transfer is determined by the CG height and track width.The other function of anti-roll bars is to tune the handling balance of a car. Understeer or oversteer behavior can be tuned out by changing the proportion of the total roll stiffness that comes from the front and rear axles. Increasing the proportion of roll stiffness at the front will increase the proportion of the total load transfer that the front axle reacts and decrease the proportion that the rear axle reacts. This will cause the outer front wheel to run at a higher slip angle, and the outer rear wheel to run at a lower slip angle, which is an understeer effect. Increasing the proportion of roll stiffness at the rear axle will have the opposite effect and decrease understeer.
I may be wrong but the part that is highlighted may refer to decreasing understeer, but may increase lift-off oversteer, or just oversteer in general. Feel free to flame me if I am wrong.
ForceIndia
  Gentlemans spec 200
Fred helped them with this review:
WE’VE TRIED IT: Another day, another Renault, this time a Clio 182 in issue 6 fitted with Whiteline’s adjustable anti-roll bar. This is a much simpler and cheaper mod than full coilovers, of course, but don’t dismiss it because of that – we thought it was an excellent consequence-free suspension upgrade that would work even better with a full chassis set-up. As it was, it turned a dynamically competent car into a scalpel-sharp front-driver with nothing more than a 20 minute bolt-on modification.
  Lionel Richie
where'd you find that? don't post my mug shot!
  172 ph1
More roll stiffness at the rear definitely decreases understeer / increases oversteer, so it's probably recommended for those suffering from understeer
I didn't think I needed it, but as I've had to raise the front of the car to avoid driveshafts rubbing on the body, I'm starting to have more understeer, so might end up having to get one
