Windback Tool??
Coby.
  XC60-R.......V40-R
I'm changing my Front Disks and Pads and will be changing my Rear Pads aswell, Do I need a Windback Tool?
If I do what is it and where can I get one from??
Andy
MRBILLYUK
  FF Jeden Osiem Dwa
Use a screw driver or a piece of square bar to wind back the piston into the rear caliper .
Coby.
  XC60-R.......V40-R
OK Excellent.... I was hoping not to have to spend anymore Money :)
Coby.
  XC60-R.......V40-R
Thats good to know... We've got plenty of Tools at our convenience and a fair bit of knowledge so hopefully all will go ok.
  Ph1 172 + Combo van
on the front just use a big pair of grips to push the piston in until it stops.
G-clamp works well too. Remeber to undo the reservoir so the air can escape not sure if its 100% nessasary but can't do any harm
^ you'll probably want to be drawing off some brake fluid from the reservoir if it's currently topped up and your pads are particularly worn
  R5gtt, 182, volvo...
do it before you take the caliper off, screw driver behind the rear pad and lever it in.. job done..
one side at a time and DO NOT push one in while the other calipers in bits or the piston on the other side will pop out.. very messy..
