Window would not come up (misaligned)
  not a clio anymore
Hi all,
My driver's window has developped a fault. Yesterday, I heard (maybe unrelated) a sound on my side as I was driving. Next, I put my window down (car park access). Park the car, then the window would not go back up. It was completelly tilted forward and could not move up.
There is a little black metal clip thing at the top of the window that looked somewhat broken.
Thanks to the AA my window was put back up but I need to fix this. I seem to recall it is a common issue so what parts are invloved and is it easy to fix yourself?
Do I need just the little clip or do I need to buy a whole new door?
did the AA guy explain what had gone wrong?
i'm not familiar with the Clio window mechanism but, if it's the same as most others, it sounds as though one of the slider wheels has come out of its channel in the bottom of the glass.
difficult to explain but, if this is what's happened, you should be able to figure out what's going on by removing the door card and having a look at the winder mechanism in the door.
