Xenon bulb
Hi one of my xenon lights has stopped working and was wondering what type I need as I want to order it off eBay. Is it a h7 xenon bulb? Cheers
  Clio 182 FF
As Said above swop ballast over first or may be easier to swop bulbs over. I though my bulb was gone swopped then over abd it worked but the other one didnt, turned out bulb was fine and was the ballast
The xenon started to go a pinky colour, then it just went off. Only got one working now. Just had ago and it's a bigger job than I thought, hmmm.
  Impreza Wagon
You can change your sidelights without removing the bumper, it's tight but it can be done. Not sure about fitting xenons, but I'd imagine it's a front end strip down!
Apparently It can be done? not sure if I read that correct or not with the bumper on.
but its so easy to take the bumper off, just takes a bit of time, my only tip is use masking tape on the front wings each side where the bumper goes back on, otherwise you can scratch the paint when re fitting.
