Xenon fitting guide
  Bumder With A Buffer
I can tell u how to do it....
Take inner arches out
Undo 2 bolts on each side holding the bumper on
pop bonnet open and UNO the little lug things under there.
Pull bumper off
then u can undo the Xenons and change the bulbs.
U could do it without taking the bumper off if u had hands the size of a one year old!!
Da
  Less
Rich has told you how to change the lamps in a car that already has xenons.
You will need to remove the bumper, then there's 3 bolts securing each headlight in. Remove the adjustor from your headlights and fit to the xenon ones.
Bolt lights back in place, connect the wiring and put bumper back on.
