XP SP3 Update...
  Clio 197
...I know it's a cumulative update, but:
Do I still need to update IE6?
Do I still need the GDI+ detection tool?
Ta,
Oms.
Darren S
Haven't really noticed anything good or bad about having SP3 installed. The only issue I've come across (usually on laptops) is with the Microsoft UAA sound support. If the chipset requires this to be installed - it works fine on SP2, but gets killed on SP3.
That was a few weeks ago now, so they may have released a patch for it. And you don't need to worry (or use) IE anyway. Firefox is much better. :)
D.
dk
  911 GTS Cab
it contains the new RDC client for connecting the windows terminal services gateway 2008, only way to get it.
  Better than yours. C*nt.
D.
You need to reinstall the sound driver after SP3 install - it's because SP3 installs UAA support, which I believe can occasionally cause a problem when it's been installed manually.
Darren S
D.
I've tried that on the ones we have at work m8, but its still no show. The driver gets installed fine - no errors or anything, but there is just nothing at all through coming through the speakers. Try it with SP2 alone and all is well.
I'm up for giving it another try though. We've got another laptop due in the office tomorrow that I'll be downgrading from Vista Business. See if it works then. :)
D.
  Clio 197
I've installed it:
My computer boots, ready to use, a lot quicker than if I had installed all the updates individually.
I'm guessing that having a million small individual updates bog the computer down somehow.
