Ok, not often I help out here anymore because no one gives a s**t.....
Get your wash technique sorted first. No point in removing swirls only to remove them again.
Shampoo:
BTBM - Leaves no wax or sealant deposits and leaves your wax/sealant to do the protecting, really is kind to wax. My personal Favorute. Expensive and only in 1L, 500ml, 250ml.
Gtechniq G wash - Slightly cheaper and similar to BTBM.... Something doesn't cut it though, I think BTBM is nicer.
Shampoo Plus -Best Bulk Out there IMO. Has gloss enhancers IIRC.
HyperWash - Second Best. Better dilution ratio, but always seemed to me pretty harsh to wax.
Zymol Auto Wash (Dark Green not light green). My favorite off the shelf shampoo at halfrauds.
Snow foam -?
G101 with hot water as a pre-wash in a sprayer. Nothing else comes close or doesnt rape wax.
Daemon Shine RDS - Good alternative
Auto Finesse Citrus Power - Fucked my paintwork up good and proper when it was really hot during the summer.
Anything else is a waste of money
Wax - ?
If you LIKE waxing and have the TIME for waxing...... Zymol Carbon....My favorite. Lasts long enough to be durable and cheap enough to wax whenever you feel like it (IE every week)
Autoglym HD wax.
FK1000p
In that order. Don't bother with anything else....
Sonax BSD.....
Polish - ?
Machine polishing varied car to car... but hand polish see below...
Black Fire GEP - Best filler/Cleaner available Out there but pricey at about £22
Autoglym Super Resin Polish - Like AF tripple but has a slight cut to it, so is better for paintwork cleaning, removing oxidization on red paint and removing some stubborn marks.
AF tripple.. AIO, so Fills, cleans and polishes in one. Great Stuff
Wheel cleaner - ?
Sonax Full Effect - Too expensive for some people but its all I ever use now, like Iron X but not lethal.
Iron X if you can afford it - Will decimate 'pitting' and that yellow/orange bakes on dust. Not for regular use.
Espuma Revolution - Lethal s**t. Removes everything except pitting (iron deposits). Not for regular use. Expensive too
Bilberry. The bitches wheel cleaner. Useful only for removing brake dust. Wont touch burned on yellow s**t.
Tar remover -
AutoSmart Tardis
AutoSmart Tardis
Did I mention Autosmart tardis
Clay bar -
One of the 3 available Bilthambers depending on requirements.....
Unless your paint is proper fucked then Megs Red. Only use of machine polishing after cause that s**t will marr your paint to f**k.
Wash mitt -
Baller Large - Dodo Wookie
Baller Small - Eurow with thumb
Pro Sponge - The black one on Elite Car Care is my favorite. All I ever use.
Wheel brush -
Any Small round detailing brush, an EZ 'GO' brush if itll fit is the best one. Or a mini. Avoid the larger one.
Microfibre cloth to get round the back of the wheels.
Trim restorer -
Gtechniq C4.
That Auto finesse revive? one if you're one a budget.
Dont consider anything else.
Tyre blackener -
Megs Endurance
Megs Endurance
Megs Endurance
Megs Endurance
Did I mention........
Glass cleaner -
AF Crystal - Best one IMO
AG Fast Glass or 3M aerosol off the shelf.
If youre not going to machine polish then you need a pre cleaner, ideally with a filler (See the 3 I mentioned, then top with a wax, sealant, or spray sealant. Like BSD :quiet
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
