182 jacking points
were under the car would you jack up the front and back of the car with a trolley jack, ps i wont ust the original jacking points
thx
shaun
ps pics would be very very helpfull lol
  Scenic mk1 (F3R)
front wish bone and rear axle id have thought would be fine
[Edited by Loki on 4/3/2005 1:28:06 PM]
  Lionel Richie
jack it off the chassis leg on the front (square section of metal under the car, about 12inch in from the sill)
Trolley jack on this point will lift both front and rear wheels off the ground
right, thx for that, anyone got pics of this bit, to demonstrate were it is, i only ask as i jacked an old car up once and it creased the panel under the car !!!
Stay Puft
  Clio 172
Archived Post from old forum
Very old bump. Anyone have a pic of where this is? Dont trust the sills and struggling to find anywhere else which looks safe to jack.
Amos91
Honorary Member
Plenty of info around.
Front I go here on the support bolt -
Back- just go off the sill as its light or the rear beam.
Stay Puft
  Clio 172
I did try that bolt but was worried. Ended up finding the guide and have used that rail bit.
R3k1355
Jack under the bolt and a stand under the chassis rail, I leave both in place while working underneath for security.
Rubicon_
  Defender 110
Has anyone ever centre jacked from the front with the subframe? Needing a solution to a single garage :expressionless:
  PH2 172
I have had a subframe reinforced with plate for this purpose.
I`ll get round to fitting it once painted it & the weather is a bit warmer, along with black polybushed cup wishbones, ARB & rack bushes.
SUBFRAME 2017-01-07 18.36.21.jpg SUBFRAME JACKING POINT 1 2017-01-07 18.35.51.jpg SUBFRAME JACKING POINT 2 2017-01-07 18.35.58.jpg
  Clio 182 Trophy
I got fed up of struggling to Jack the car up and bought a 3t SGS Trolley Jack. It's chunky so I have to drive onto a brick to lift the car up so I can get the Jack under.
Stay Puft
  Clio 172
I put 50mm concrete coping stones underneath my jacks , its a more solid base and gives you an extra 50mm height to start with so you can get the axle stands under the frame rails .
Something like this :
https://www.google.co.uk/search?q=concrete+coping+stones+travis+perkins&biw=1922&bih=945&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjj6tbekr3RAhWrL8AKHagIDnoQ_AUICCgD&dpr=1#tbm=isch&q=concrete+coping+stones&imgrc=-JZfUSs5xGZJmM:
Surely that would make it harder for me as I cant get the stands under the car?
MRBILLYUK
  FF Jeden Osiem Dwa
Put the coping stone under the jack and jack from the sill , then you'll be able to jack up 50mm higher than you would normally with the jack . Put the axle stands under the frame rails not the sills . I'm off to work in min or I'd search for you on here . But if you look for jacking points / axle stands you'll see exactly what I mean with putting the axle stands under the frame rails .
https://www.google.co.uk/search?q=clio+182+rear+jacking+point&biw=1922&bih=945&source=lnms&tbm=isch&sa=X&ved=0ahUKEwiwkob3mb3RAhVqDsAKHTHHCesQ_AUIBygC&dpr=1#imgrc=rAL9nhQHuiX-vM:
http://www.cliosport.net/threads/jacking-the-182-up-please-rear-front.353799/
  Clio Trophy
So what's the best way to go about setting the car on 2 axle stands at the front if there isn't a place in the centre to jack it?
Is it too dodgy to sort an axle stand on one side then lift the other side?
  330i. E30 Touring.
Yep, as above. Jack at the front chassis rail, axel stand on the jacking point on the cill. Move to the other side and repeat. Rear, jack on the rear beam, 1x decent axle stand in the centre of the rear beam is enough.
  330i. E30 Touring.
I was going to go with the stands at the rails shown in post 7 where the axle stand is sitting.
Can do that, but i prefer mine on the cills. Gives the car a bit more stability, especially if you're doing any work that means you need to give it a bit of welly.
leeds2592
  Bean 182 + E70 X5
That's where I put mine. Always been sturdy enough for me.
When you've got it on the 2 stands, just give it a good push to make sure it isn't going anywhere.
chris blue
  172 Ph1 2001
anyone got a photo of where on the front chassis rail, or is it on the bolt as the photo earlier post 7#
Ive got mangled (Hasnt everyone) jack points, and would like to jack from the chassis rail just behind the front bolt joint, but it looked like it was giving a bit when i tried, so went back to the mangled jack points
will give it a go as the photo above
The amount of times i take wheels on and off for track days, may have to get the jack points sorted- any idea how much?
  PH2 172
My apoligies for the poor photo.
I had plates welded to the front subframe and can get 3 wheels off the ground at the same time.
  PH2 172
Looks great- how much it cost you to get done?
About £30, + a subframe, as it was one of several little jobs I gave them at the same time..
All PH2 subframes are the same if you are looking to pick one up, before someone starts some nonsense about Cup`s being different.
chris blue
  172 Ph1 2001
cheers for the info- i'm a phase 1 172, but will ask Clioman (Trader) see if he can sort some better jackpoints for me
Anyone recommend a lightweight low entry trolley jack- under 10kg. A carry handle be nice too.
