Clio 172
Fitted new rear discs went to refit brake pad carrier and the bolt holes don't line up. The piston is wind right in any ideas?
Yes and the correct way.Did you put the spacer back in behind the disc?
Yeah lug all lined up. About 3mm out. It seems like it's the thickness of the discIt's been a while since I've done rear brakes on a Clio so I can't think why the holes wouldn't line up.
How far out are they?
Thisslide the caliper :tongueclosed:
