Noob brake question
  BMW F30 / Clio 182
Hi there,
Being a bit of an idiot, I've taken a look at my 197 calipers and for the life of me can't figure out how to remove them for disks and remove the pads.
Am I missing a trick here? Look massively different to standard calipers
Chrisgti6
  MR2,TT V6,Mini x 2
No need to remove the calipers. Just knock the 2 retaining pins out and the pads can be removed.
Chrisgti6
  MR2,TT V6,Mini x 2
If you want to remove them, the standard bolt is a 12mm female hex head bolt. Remove them and the caliper can be removed.
  BMW F30 / Clio 182
Cheers, the retaining pins as in the springy ones over the pads, or the 2 that go straight through the calipers?
  BMW F30 / Clio 182
Oh goody! I've seen these rebuild kits
Is it worth just refreshing them at the same time?
Djw John
Scotland - South
Yeah I'd buy that before you start the job. Or you could find the car is stuck up in the air with no brakes until they arrive.
You can guess how I know.
  BMW F30 / Clio 182
Same way I learnt that TRE use bat s**t crazy tools and nuts? [emoji23]
