STRBramley
  182 Trophy #404
Have you got a guide on how you did this. I never use my cig lighter so may as well use it for something useful like you have done.
It was pretty easy. The only time consuming part was filing down the hole for the new USB connector to fit in.
I've linked the one I bought below (although it seems to be a different colour now). It comes with the connectors so you can simply cut your old cables, strip them and then crimp them to the new USB.
https://www.amazon.co.uk/gp/product/B07TZM8PRL/?tag=cliospnet01-21
Let me know if you go ahead with it and have any issues. I'd be happy to help.
  172 Cup
First Job was to sign up as a paid member, secondly I wanted to change the silver bee sting aerial for a standard (shorter) black one.
And finally the bullet badges had been painted black, which were peeling. Upon removing the N/s bullet badge I found it had been held on with some putty adhesive, after closer inspection and when attempting to remove the bullet the whole side rub strip was peeling away. It became apparent that that too was held on with strong adhesive.
Onto ebay I went to source some standard silver bullet badges and a mondial blue N/S rub strip.
After an hour or so of peeling,scrubbing and prodding I managed to remove all the adhesive putty and sand the area down. On with the side strip and bullet badge. And back to standard! :)
  Clio Sport
I have just bought a Auto Glym headlight restoration kit...I did try with a turtle wax kit awhile but it didn't work..so it's probably £25 down the pan..
Amos91
Honorary Member
Engine bay tidied up - bonnet catch rust treated and resprayed & replaced the upper engine mount as it was a bit rusty (3 years old).
Then onto the rear beam in preparation for a PMS anti-rollbar and new bushes (the last ones to be updated on the car).
Rear beam dropped and now off with the powdercoaters -
Useful little brake line blanks -
With good access to the rear of the car I decided it was now a good time to look for and treat any surface corrosion -
Grinded back, this is where the rear springs meet the body -
Treated with Hydate 80 and ready for undersealing -
Fuel door removed (and now the fuel cap etc), only a little rust but on the list to treat before putting the rear beam back on -
Also replacing the rear brake lines (already received from RPD) and refresh the rear caliper slides as one was actually siezed.
Looking forward to getting back out in it for spring!
LostInSpace
Service done by The Clio Man in Littlehampton, also fitted HEL brake lines and PMS RARB.. First time the car had been inspected by a specialist and he gave it a very clean bill of health, bar a crack and leak in the rear of the centre exhaust silencer - need to decide if I want to fix that or replace. Boring drive home in traffic gave no opportunity to see how the RARB effected handling, will have to wait for a blast at the weekend. Alignment, headlight restoration are next and it's in need of a wash and wax top up.
DomP182
  ph1 172, Arctic182
Debobbled my replacement seats for my 172, 180 grit sandpaper does an amazing job if brushed over it carefully followed by a bic razor
MarcB
  Too Many
I would really like to say something different but one again.
Opened the door, Switched the light on, Had a look and then went and and messed about with something else.
benji93
  ph2 182, mk1 mx5
Foamed it, blasted it and left washing it for another weekend
  • VID_20191124_124627.mp4
    19.2 MB
DomP182
  ph1 172, Arctic182
Went to start it only to find the new battery flat, I must have a drain somewhere🙁
CrippsCorner
  Astra VXR
Passed MOT without even a single advisory, not bad for a 14 year old car! Time to start writing the for sale advert soon 😖
  Clio 172 Cup
So the 172 Cup went in yesterday for a full service had a couple of advisories on mot so had anti roll bar bushes replaced with Powerflex items and inner ball joints done. Stripped the spoiler stop light and cleaned and that’s working again now had a full alignment done and what a difference now to the handling , hopefully I won’t be spending for a while now just try and enjoy the car
DomP182
  ph1 172, Arctic182
Fitted 16mm hubcentric spacers to the front which took longer than it should have thanks to a seized disc retaining bolt that was proud of the mounting face, a centre punch saw to that eventually.
Started to fit PMS 10mm stub axle spacers to the rear, wasn't all that bad considering the 17 years of corrosion on the four hub bolts however this has lead me to think I need to overhaul my calipers judging by the split seals and general grime build up.
DomP182
  ph1 172, Arctic182
I'm not happy with that now, I should have cleaned the hubs up and painted them but fitting it all in was going to be tight. I think I'll be stripping it back down when we get lighter evenings but at least the bolts will come off easily.
MarcB
  Too Many
Over the last few days ripped the front bumper off teh car, Changed nuts & bolts from rust to new Allen hex heads and also popped all the Grills off also as have new ones to put on but want to give them a coat of gtechniq C4 Permanent Trim Restorer to have them looking really fresh.
colesy
  172 182 197 E61 530D
Just a quick clean today
DomP182
  ph1 172, Arctic182
Finished fitting the rear stub axle spacers, found a new problem
