4 pots on 182
  Clio 3 1.2 tce 2010
Hi there what braided brake lines are people using on the clio 182 with 4 pot callipers I have found the ones pictured below but not sure if they are compatible
Many thanks
Yarp
  Clio 182
Could I not run standard 280mm discs with the standard 16 wheels that’s what my thought was???
You could but the only reason to run 280 is to fit 15s. If you’re sticking with 16s go for the bigger disks.
You can use disks off a early 2000s scenic of some flavour and they are cheap as chips
