Ph1 Track Car.
  E46 M3 + Ph1 172
Ill let the pics do the talking
  E46 M3 + Ph1 172
Future plans are Rockingham on the 18th August, PMS shifter and a set of DZ03's over winter, maybe braided lines and ATE fluid, then more trackdays next year..
Cheers, Just made it from abit of studding and a adjuster bar, an idler and bit of plate, works and seems pretty reliable so far :)
  E46 M3 + Ph1 172
Ta, got some shorter bolts for my perspex windows, they need fitting. And was thinking about making a block that bolts to the ARB using both holes, less chance of that bottom bolt bending then...
Was getting fed up of tightening the bottom shock bolt as the angle plate wears it loose. and the fact the standard part is/looks crap
  E46 M3 + Ph1 172
Pax side done
Looks loads neater, but wanted to be able to get hand out of drivers side, just incase..
  E46 M3 + Ph1 172
Feeds into an ice cream tub thats bonded where the heater matrix goes through the bulkhead, then 2 pipes out the bottom of that, one for the driver, one for passanger.
Lets a decent amount of air in, we had to put a rag in them on the way to blyton last year as it was too cold lol
  E46 M3 + Ph1 172
You keep bailing out of the trackdays :p
Rockingham, 18th august.
​P.s. How much have you spent on yours?? and what were your cadwel lap times?? ;)
  E46 M3 + Ph1 172
Its got nothing in it lol...
Still got steel doors, boot and rear glass...
New wheels weigh 6.2kgs each...
No idea of the seats, alot less than 1 wheel though...
  E46 M3 + Ph1 172
Yea without tyres..
Keep chopping bit outs, the strip under the drivers feet is pretty heavy, theres a lump of iron under the engine mount on the inner wing, the glass weighs a ton...
Id like to chop the origional seat mounts out and get rid of the subframes, but would rather spend the £100 for rails welded in on a satchshift..
  E46 M3 + Ph1 172
Cheers, didnt want to f**k the paint up on the outside of the roof by heating it too much.
Ill get it removed over winter..
Just got these for the 1.2's
