Battery Nonce
The car starts fine usually after 1 or 2 cranks however when driving and coming to a stop when pressing the clutch, the revs will dip ever so slightly.
Setting off can be a pain too, it's like my clutch is on its way out even though it has just been replaced and then the car judders and I notice the lights on the dash dipping a bit. It's as if the accelerator isn't doing anything for a bit.
Also noticed that if i'm in second gear and holding the accelerator at a certain point the car will kangaroo it will drive like this: fine fine fine fine dips the power fine fine fine fine and then repeats.
It's so annoying as setting off is becoming a juddery mess!
Wondering if it sounds like my TDC needs replacing or cleaning.
Cheers!
Cheers!
