ALTNATOR FIRE HELP AND ADVICE ?
  R27 427/500 ALBI
Hi recently had a altnator fail just stoped working replaced it with a used altnator for a good price from a renault specialist in accrington its been on little than a week and its gone , it started smelling them was billowing with smoke , opened the bonnet and it was glowing red and a small little flame from there ,
Not had any problems with the trophy but can anyone sugest what may be the problem or is it just bad luck ?
Just cant think of anything that may cause it or any under lying problems ? , its well maintained and always has money spent on it.
Nerly had a heart fail once smoke poured out ...
Any help would be appricated ..
Leigh
  Inferno 182 & Saxo
Must be a bearing for the pulley I'd say or something along those lines. Must have seized
  R27 427/500 ALBI
And caused it to over heat and started heating the carbon and the plastic on the altnator casing ? Just my luck , see if anyone else has had any simlar problems cant see any ?
  RS mk2 172
I have had an alternator overheat and read of several others on here previously (one even resulted in the car going on fire), it seems to be a common failure and given that you replaced the original one with a used unit I would say you were just unlucky.
My 182 did the same although not quite as hot. They get an internal short in the windings.
2 in a row is bad luck, but for me second hand alternators have always been trouble, same with starter motors.
  197 FF Glacier White
Leigh
I personally wouldn't buy anything from that place in Accrington, everything I've had from there in the past has been poor to be honest. Maybe I was unlucky but you try taking anything back to them!
G
  Mondeo TDCI 130
Bad luck on your part! But i honestly struggle to get my head around why you would buy a secondhand alternator for a trophy?!?!
I would buy a secondhand alt for my scabby pug, but it's only worth 50p!!
Trying to save a few quid could of ended up with losing the car all together!
  R27 427/500 ALBI
To be fair it was off a 22,000 mile old car so didnt suspsect that but then again how long had the car been sat there , Ive never skimped really on the car but £230 vs £50 and looked good condition , Will all be sorted very soon i hope.
jenic
Bought my alternator used, off 172 ben, i believe you had fit it about 9 months before i bought it so if it goes wrong ;)
