FOR SALE!!!
need bit of adivce fitting a sub and amp in a n reg punto the wires were already in the car but the amp will not power on i have done quite a few sub and amps in the past i have checked the power lead is working by touching on to bare metal it sparked well and also cut the end so fresh wire is showing the ground wire is on an orignal ground point in the boot and remote wire is on an amp power out wire on the back of the head unit which is marked as amp remote wire i have also tryed the remote wire on a few more of the wires in the back to make sure but still wont work checked both the fuses that are in the back of the amp to 15amp's and they are fine
when i pluged a set of rca leads in red light flashed on the amp and then went back off so im a bit stuck to why it wont work could it be there is no isloated fuse on the power wire its just the wire all the way to amp also the head unit doe not turn off you have to take the front panal off to turn off but this happens on my other mates punto to so could it be the fact need to take off all the leads of the battery so it will reset the head unit our do you rekcon the amp is fired it come with the car but subs removed etc any advice would be great
