I'm having a bit of an issue with my car when I drive over a bumpy road the car knocks from the front and it feels as though the front wheels are loose or something. An I right in thinking the ball joints are shagged?
I had this the other week, easy and cheap fix as long as you don't empty the contents of the gearbox all over the floor like i did! If you do end up doing the ball joint you can get them from a motor factors for under a tenner, id recommend a splitter fork from halfords too which is under a tenner also, make sure you think about the order in which you undo the bolts so as to make sure you pop a drive shaft out.
