You'd need to bump up to a 205/50/16 but Yokohama A052 is the best road tyre on the market currently. Quicker than most semi slicks in the dry, yet are comfortable, progressive and work from cold. They are also decent in wet conditions.
I considered this but im only just getting away with a 45. A jump to 50 and they will be catching.You'd need to bump up to a 205/50/16 but Yokohama A052 is the best road tyre on the market currently. Quicker than most semi slicks in the dry, yet are comfortable, progressive and work from cold. They are also decent in wet conditions.
I considered this but im only just getting away with a 45. A jump to 50 and they will be catching.![]()
Will fit fine for you mate, my cars quite a way down, so no good for me.Frayz you think 205/50/16 wont fit the stock 182 Trophy wheels ? Would be pretty epic if they did
If you can get a finger with wiggle room in the arches you'll be sound.Cheers guys. Just a note to add .. I am running Mark Fish Springs which lower the car by 15mm
I'm really fussy about how I like my car to drive, i like a stiff sidewall that makes the steering responsive and alive. Therefore the full winter and rain tyres i struggle to put up with even in winter. In summer i drive on an R888R daily and winter i was/am using the PS3. Previously i have commuted on NS2Rs 365 days a year and don't have any issue with their performance in any weather but snow. Their only drawback IMO is their noise. Yes they're soft but offer more grip than 99% of regular road tyres and wear accordingly. When my PS3s die, i'll go back to NS2Rs for winter, not ideal i know, but i know and like how they feel.
Or maybe try the Hankook as these seem to be the best of the rest for an all season tyre
My winter wheels are Turinis which are 16s. I can’t get any in a 16” ☹️Just had new PS3's fitted all-round on mine (15").
After using R1R's for a few years you can defintely feel the softer profile.
Did a bit of weaving side to side and i thought something on the rear end was broken, a very floaty feeling 😂
Don't bother for a daily, they need a bit of heat to work, fine in summer but won't be great in current conditions. Also for track they only hold peak grip for a few laps before dropping off.Who has experience with A052 for daily use?
Ive been running ZV7s for a couple of years now. Can't fault them in the wet or dry. I used to run rainsport 2's then 3's. They're a good tyre, especially in the wet as the name suggests but I would only get 5 - 5.5k out of a set 😮 I just got 12k out of a set of ZV7s 😊I've just replaced my front two with the much maligned Zv7's!
I was running Rainsports which were OK.
All depends on your current arch gap. Going from a 205/45/16 to a 205/50/16 is an increase in sidewall height of 11mm. Say if you current arch gap is 20mm+ I'd say you'd be OK for road use.Bump
Did you end up doing the 205/50 A052s on your Trophy? I'm currently considering doing the same on mineThank you! Appreciate the reply and advice there.
