Broken mount?
  Clio 172 Cup
The car shakes under acceleration, the higher the rev the louder it shakes
i think it may be a gearbox mount because if in 5th and you put foot down on accelerator quickly it does a really big shake
caused by a section of road which was a bigger bump than it had looked:/
i believe its it's a mount because my engine mount broke in the Saxo but in this it doesn't shake as much and seems to be coming from lower down. At the front
  Clio 172 Cup
Well it does move a little (Only if you let off and then accelerate again) but I dunno what it was like before the problems started.
During idle the car is fine but when pulling away there's a huge vibration, same as when accelerating. But when coasting or keeping a constant speed it is fine and there is no shaking.
When braking there is no shaking.
