Checking timing question
Norris1
  Ph1 172
I've got the timing tools but do I need to butcher the cam seals and replace with new ones to check the timing?
  Lionel Richie
and the horseshoe should slot in with MAX a tiny wiggle, forcing it even slightly doesn't count as "yeah timing is fine mate"
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
Whilst you're there check there's no "play" in the inlet camshaft from a worn dephaser as this will 100% add some advance to the timing knocking it out slightly. General rule though is as per Freds post above.
Mick
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
No but use the genuine ones as the APA versions are s**t! They leak baaaaad and some fit so badly the oil pressure pops em out.
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
Exactly Fred, they just fall out from the weight of the oil on them
