172 phase 1
i need a NSF hub for my 2003 clio 172 cup
as someone left the pinch bolt loose and the hole the balls joint sits in has worn away resulting in movement even with a new ball joint and pinch bolt,
my question is
is a normal 172 hub the same as a 172 cup hub, as im aware the clio 172 cup has wider front track and no abs
my question is
