Cylinder order/ Firing order/ coil pack?
Drakec
  Bmw m635csi,polo.
My Clio 172 I recently purchased has a throttle body conversion.
It was running fine but I have stripped all the loom and redone it as it was a mess and bodged together.
I labeled everything up before I cut the loom out so it’s gone back as it was.
But I have just noticed the coil leads are on the wrong positions on the coil pack and don’t cylinders go 4-3-2-1 left to right?
I have labeled my injectors 1-2-3-4 left to right on my new loom! I know i can just swap them about but it’s annoying as I have gone to a lot of work to make it look neat!
Don’t know why I didn’t check the coil pack and cylinder order first I just assumed it was right, The amount of bodges i have had to fix on this car I don’t know why😂
Anyway I can’t run the car at the moment as the manifold is off but i did start it for a second and it turned over and fired up.
I am probably worrying about nothing but would just like some clarification!
  Clio 1.6 16v
They seem inverse but the Clio coilpack usually mounts on the other side of the engine, ie. the number 1 cable is the longest. The cylinder numbers on the Clio are from the flywheel towards the cambelt.
So 4-3-2-1 from left to right, cylinder 1 closest to flywheel.
