OK, i doubt the brackets are set to allow more camber, they will probably be copies of the standard shocks
Just to confirm: Eibach was talking rubbish. The pro dampers do not fit the 172. The bolt size on the 172 is 14mm while the dampers are made for 12mm bolts (as on all other Clios apart from the 172, I suppose).
Quite annoying, really. I'm on stock dampers and Eibach springs for now, which is not where I wanted to be tonight. :banghead:
