Clio 1.2/ Impreza Type R
hi guys as some of you may recall from previous threads my dash lights have all stopped working and when i change the fuse it blows streight away i have tried to remove the front and rear lights the number plate light and cruise control panel to see if these are causing the fault but once again the fuse blows i suspect it could be the side light switch could anybody confirm if this is a possibility
