Finchspeed 172 PH2 trackday car
finch wxm
  clio 172
List of jobs I Know !
Install New rear Lamda sensor
silicone paste on exhaust decat to centre section.
Numerous ABS fault lights , possibly sensors on rear and rings up front or both !
New oil and Filter
New Front discs
Rear Boot lock doesn't lock , Solenoid maybe ?
New bonnet catch for slam panel required
2 front tyres for OZ alloys required
Install Harnasses
New wiper Blades
Check Torque on various bolts
Install AST Solid Topmounts
Purchase Rear Camber Shims
Full alignment
Paintwork is in a mess , laquer peel on roof and passenger rear quarter , not sure what to do !
Paint wing mirrors orange and track alloys.
finch wxm
  clio 172
Clio has been abit of a storage unit !
finch wxm
  clio 172
Started on the brakes today ! Car hasn't moved in a while so I stripped the rears first to clean up and regrease slider bolts.
finch wxm
  clio 172
Install New rear Lamda sensor , Wrong one turned up !
silicone paste on exhaust decat to centre section. Done
New oil and Filter
New Front discs
Install Harnasses
New wiper Blades
Install AST Solid Topmounts Done
Full alignment
refit Seats Done
Front & rear brakes removed , greased and refitted Done
finch wxm
  clio 172
Both seats now back in , Just need to fit my harnesses which are currently in the Nissan !
Steering wheel needs some dye !
Mbeau
  Clio 172
Excellent build! How close is it to being up and running? What wheels are they, look awsome.
finch wxm
  clio 172
Hopefully be ready next month. Just need to fit aerocatches and my harnesses and then need full alignment doing and shakedown as it's been off the road for a long time !
Mbeau
  Clio 172
They are some of the best looking wheels I have seen on a 172. They look spot on as does the rest of the build.
finch wxm
  clio 172
Installed aerocatches , never again !
Alignment was slightly out on one !
Broke a bolt trying to adjust the bonnet!
  Ph2 172, 106 Rallye
Ohh.. I quite like those wheels. You've gave me ideas now.
If you're ever tempted to cut your rear bumper, I'd gladly swap you (with cash your way) for my iceberg bumper that already has a cutout.
finch wxm
  clio 172
Abit more work done on the clio tonight while we still have decent weather. Got some fault codes to clear.
Majority are airbag related but think I may have a dodgy rear caliper too!
finch wxm
  clio 172
Removed the knackered abs sensor , anyone know if the bosch ones from euro will fit ? It has female connector
finch wxm
  clio 172
Track wheels complete with R888 tyres
finch wxm
  clio 172
1428958
Afew jobs done over the weekend , awaiting a replacement front wing as mine had a crack in it , clio parts everywhere
finch wxm
  clio 172
1428963
Boot lock had never worked , I had tried another solenoid with no joy , found a couple of snapped wires in loom which I repaired then re-routed, still no joy , had another solenoid spare swapped and all working , yay .
finch wxm
  clio 172
Any ideas what to do with the roof , the laquer is destroyed, roof and really rough ! Could this be revived easily ??
1429003
finch wxm
  clio 172
1429717
Installed some new slider pins on front calipers. still have the issue with the brakes , air in the system. Waiting for a mate to come round and bleed the system then try bleeding the abs pump.
finch wxm
  clio 172
Actually got it motd as I need a car to get to work in while i do some work on my daily !
Jesus the induction kit is noisy 🙈😂😂
