valve stem seals, piston rings. If it's a high mileage 1.4 S it's probably going straight out the exhaust.
As above. I nearly ran mine dry one day and it must have done some damage. Mine can go from max to min in around 6 - 8 weeks.
Did you check the oil level when it flashed empty this morning, or did you just drive it? Don't trust the dash readout anyway mate, it's never really all that accurate. I would always use the dipstick personally.
To be honest you probably wouldn't notice it smoking whist driving unless it got really bad, if it's not leaking out it must be going out the exhaust, it's the only option
Pretty much the same to be honest.
That's what I thought but theres never any smoke that comes out my exhaust.
It doesn't help when, like this morning I got in and the dash reading was flashing empty, but i've got some miles left got into it about an hour ago at work and its showing its about a 1/3 full..
