Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
Yep, one of the headlight fuses kept on blowing 4 days after I bought the car.
Took the ballast off (metal box screwed to the bottom of each headlight) and it had water damage inside!!
£180 for a single ballast - for one headlight - for one side - from Renault!
the ballast comes with a new starter - the back box fitted on to the back of the zenon bulb (D2S type). If the starter has broken the ballast wont start so the fuse shouldnt be blow in that instance. Likewise with the bulb itself as the bulb will not go short circuit when worn out!
