Is the external temperature gauge have an affect on the climate control for the car. btw i have a 172 (02) because i read somewhere that it did.
The auto mode on my climate control is always switching on the AC, i'm starting to think this as the external temp sensor is reading 50 degrees!!! Its also causing it to blow air at full speed and not reduce the fan speed.
Is my theory correct?, in saying the climate control thinks it hot outside (due to the external temp gauge reading 50 degrees) so its turning on the air con and max fan speed?
Has anyone else experience this? Does the air con come on in this cold weather when you use auto?
