High compression engine
  Clio b phase 1 Sport
Hello.
New here on ClioSport.
I have a 172 phase 1.
I have it for a while,it feels
A bit down on power.
I want to build high compression engine with
New KTR rods,high compression pistons 13:3 (original 11:1),K-tec catcams camshafts, KTR valve set,upreated valve springs,
ACL Race big end bearings.
Someone experienced with this set up ?
Do I have to change injectors,fuel pump ?
Can I flash the original ECU by EuroDayne ?
What ECU tuning is recommended ?
Is it a good set up ?
I know that it isn't far from a turbo project price but I don't a turbo fan.
What amount of power you think I can get from this motor with a fine tuning ?
Thank you mates
SharkyUK
Hello.
Thank you mates
Definitely buy them from somewhere else, such as from Dan. You will save a lot of money. It will get very expensive and you may see anything from 210-225bhp depending on the underlying strength of the engine.
