Indicator fuse blowing
scotiamr2t
  Mazda 2, Ph1 172
Have an issue with the indicator fuse blowing. Only occurs when indicating left or using the hazard switch! Indicate right an there is no issue
I have replaced the hazard switch, tried a new stalk and checked the wiring and as far as i can tell the wiring is fine. Checked all earth points an they are as they should be so at a bit of a loss
Anybody any other suggestions?
scotiamr2t
  Mazda 2, Ph1 172
I have indeed mate, i have checked and rechecked everything an cant find the fault. I shall get in the garage tonight or tomorrow an go over it all again, have a new set of rear and front lights to try now
R3k1355
Earth points on the rear lights are a known issue, bit of water or something gets in and causes corrosion and odd electrical issues.
Might need to take the lights out, and clean up each and every connection thoroughly.
