2005 Clio 182 FF
Is this a common issue? Im replacing the dephaser and the timing belt, I have the crank locked at TDC , the exhaust cam is lined up correctley but the inlet cam seems to be as much as 10 degrees off the centre line. Is this common? Can I just whip off the TB then re align the cams , lock them up and refit the belt and dephaser?
