Issues!
This is the nearside connection for the main beam bulb on my Ph1 172 -
http://i2.photobucket.com/albums/y43/badinvincible/mike024.jpg
The light doesnt work...
This is the connection on the bulb -
http://i2.photobucket.com/albums/y43/badinvincible/mike028.jpg
As you can see, its melted to f**k...
It should be like http://i2.photobucket.com/albums/y43/badinvincible/mike025.jpgthis and http://i2.photobucket.com/albums/y43/badinvincible/mike026.jpgthis
The side that isnt melted works fine. The side that IS melted doesnt work at all. I tried putting the melted bulb (element is still there) onto the unmelted connection and that doesnt work either.
Can anyone help...?
Has
  RS 182 - Black Gold
did u have to powerfull bulbs in there?
where they somethign like the Halfords Rally ones|
Or simply standard bulbs :S
KDF
  Audi TT Stronic
Sorry to hear your still have troubles with this. All i can say is that the melting is normally caused by too much current being drawn through too small a core wire, which generates heat etc.
Its a little bit like a lightbulb.. put enough current through a high resistence bit of wire and it gets white hot.
  2005 Impreza WRX STI
u will have to get new connecor mate and in linbe crimp it! easy job but will prob be fiddly as theres not much room!
Just cut the conenctor off, solder the wires together and insulate....or if you wanna be able to remove then use spade/bullet connectors
  Suzuki SV650
Ouch, problems all over the shop, hope you can get your hands in there ok, theres fap all room in there ay.
