ph2 172
whos got one? how do they rate it? looking at purchasing one.
Hi,
Just had one fitted, fitting is spot on, sound is very subtle. Exactlty what I was after-(I am nearly 40!)
Greeny; did yours come with the seperate hangers that you attatch yourself?
if so i spent 15-20 mins adjusting and manouvering to get the best fit, will put pics up later
We always find there are some garages that just cannot fit an aftermarket exhaust and they are very quick to blame the exhaust for their own failing to fit the exhaust right.
The system has not be redesigned, they are all the same and should all fit very well. Greeny if you are ever down this way I will gladly have the guys in the workshop fit your system correctly for you at no cost to yourself just to show you how it will fit once done correctly
David.
