Load sensing valve
Flooky
  172 CUP, D23 Navara
Can anyone confirm if the 172 Cup has a brake load sensing valve fitted as std with the arm and spring?
Failed the mot due to the arm and spring missing...
MarkCup
No it doesn't.
It failed the MOT becausae the tester is a muppet, not because of the alleged missing part.
There's a VOSA guide somewhere which you should print and take along to educate them.
Flooky
  172 CUP, D23 Navara
Nice one! Cheers for the quick reply.. I shall find this document from vosa and get it printed.
  Lionel Richie
yeah it would've failed its MOT previously and someone unaware of the setup on the cups assumed bits were missing and fitted the bits that aren't meant to be there
i'd remove them!!
