hi where do peaple measure the ride heights as i will be fitting my 16" alloys and getting rid of the 18" alloys:clap: tomorrow.
is it best to measure ground to sill
or rim to arch
thanks for advice in advance and ill post some pics after
j
You can measure it from anywhere so long as your four refference points are the same height (or you know the difference in height of your refference points - but it'd be much easier to pick the same place e.g. front and rear of sills)
I wouldn't measure ride height using the gap between the wheel and the arch since that's arch clearance. Thought it's true that if you lower a car the difference in arch clearance will be the same as the difference in ride height it doesn't give you "ride height" in the true sense of the word.
